Brake booster!!!!!problem
Ok so i know i have a bad brake booster.... I have heard rumors it is pretty difficult to change yourself...shop over here in north las vegas "hondoctors" is charging me 170 to do this job. I really am pretty broke right now dont have the money to do it.. I was gonna try to do it myself....does any one have any write up on this and what is the level of difficulty 0 to 10 and how much time will it take me?? Thanks
hey i just pulled a da booster so if you wana come to my garage we can do it and ill give you my good booster. bquinn702@yahoo.com hit me up that job take 30 minutes
IF you do it, just make sure you have the tools.
There are a couple hard to reach nuts to remove.
I remember using a couple extensions and maybe a wobbler joint to hoook up to them with a socket. Might have been a deep socket too... been a while.
the two bolts from behind the firewall and the upper left bolts are relatively easy to remove. the upper right bolt is the hardest, i used the small wrachet with extensions to get it off. and make sure u have nose pillars or somthing pointy to remover the pin from under the steering column.
MrMug3n
Aug 13, 2008 01:49 PM
Sloshy
May 11, 2007 10:42 AM
