swaped motor now clutch pedal is stuck on the floor
Old Dec 3, 2008 | 04:59 PM
aznpreludeSH's Avatar
Default swaped motor now clutch pedal is stuck on the floor
i recently swaped motors and now my clutch is stuck to the ground. i thought that maybe it would fix itself once the motor was running again but its still stuck on ground. everything was working fine before the swap. thx for your help guys!
Old Dec 3, 2008 | 06:50 PM
mach3lude's Avatar
sounds like the slave cylinder on your new swap is bad. replace and bleed it.
Old Dec 4, 2008 | 04:33 PM
Scheizty's Avatar
The slave may not be bad; bleeding the cylinder can take some time and effort. Get a buddy, have them open the bleed valve while you pump the clutch up and down. You or your friend should open the bleeder valve while the person in the car pumps 3-5 times. Repreat. I recommend making your friend do the pedal work. Also, make sure you use the right clutch fluid and continue to keep the overflow full. Be persistent, mine took forever.
Old Dec 4, 2008 | 08:20 PM
fixed it. i just had my wife pumping the clutch while i was bleeding it. now it works 5.0! thx guys
Old Dec 5, 2008 | 03:54 AM
JLeeBB4's Avatar
Happened to me a couple months ago...
veilsides2000
Honda S2000
Jan 30, 2009 02:20 PM
2DoorBandit
Apr 28, 2006 05:47 PM
jwitey
Apr 4, 2004 11:54 AM
speedaholic92
24
Sep 8, 2003 04:14 PM
TheMostSadistic
Apr 30, 2003 05:01 AM
