Problem! Loose clutch pedal need help!
Old Dec 3, 2008 | 04:58 PM
JasonST's Avatar
Default Problem! Loose clutch pedal need help!
So I have a very odd problem it seams. For awhile now my clutch has been engaging lower and lower and I have almost no free play in the clutch engagement. So I decided to bleed and rebleed the clutch, that didn't seam to help. Well today it got so bad to where I really can't get it into gear at all now. the problem I've found is that the actual clutch pedal is loose, the 2 bolts are tight, but it wiggles around as if it wasn't. I'm not sure what the clutch pedal mounts to, but whatever it mounts to is coming loose it seams. I was wondering if anyone else has ever had this problem or has any good advice? Thanks,
-Jason
JasonST
Dec 3, 2008 06:22 PM
Charged R
Oct 3, 2001 07:53 PM
