gsr ecu on a single cam
Old Dec 3, 2008 | 11:03 AM
r1ch1e's Avatar
Default gsr ecu on a single cam
has anyone ever tried using a gsr ecu or a si ecu on a sohc vtec?
Old Dec 3, 2008 | 12:00 PM
dividedas1's Avatar
meh pointless, why would you want your car to think it has 2 cams when it only has one? different tunes for different motors.
Old Dec 3, 2008 | 12:24 PM
r1ch1e's Avatar
because i've seen people use a p28 on an si and on an ecu it basically looks for a crank position sensor and nothing with cams if i'm correct. so i was just wondering if there would be any complications if i plugged the gsr ecu to brain my mini me
Old Dec 3, 2008 | 01:38 PM
SOHC_4dr's Avatar
sell the gsr ecu and get the stock one. its cheaper and easier. the two motors are ran differently and controlled in diff ways that also vary by the year
Old Dec 3, 2008 | 01:44 PM
Smash03's Avatar
Originally Posted by leoaa777
ricer...stick to the oem or have it tuned properly.
Foreals tho man...he asked a simple question hoping to learn something out of it. Not to get insulted.
Old Dec 3, 2008 | 01:59 PM
cashkeith's Avatar
hey i would sell it amd get a stock one you can find them so cheap so you will have some money after to buy PIZZA hhaha or some side markers
Old Dec 3, 2008 | 02:01 PM
mikehawk's Avatar
which motor would be better for my skyline gallo 12 or gallo24 ???
Old Dec 3, 2008 | 02:17 PM
BigdEG9's Avatar
p28 is obd1 dosent have a crank sensor so there for its not looking for something that the orignal car didnt have
Old Dec 3, 2008 | 02:32 PM
BoostedxEk's Avatar
I'm thinking gallo24.....
Old Dec 3, 2008 | 02:34 PM
YoungMoneySi's Avatar
you can do it. there is nothing wrong with it. my buddy has a 94 dx coupe and he put a JDM p72 ecu. he said the car had a whole new feel to it and pulled much better but he took it out. he just put it on to see if there was a difference.
if i were, stick to stock or tune that ish properly. nothing like a properly tuned car!
Old Dec 3, 2008 | 02:36 PM
Schister66's Avatar
Man U FTW
The reason you see P28s used on some B series is because that's one of the most commonly chipped ECUs. I currently have a chipped P28 running my GSR, but it has an entirely different map on it than it did from Honda. Stock ECU probably wouldn't be the best idea though..
Also, try to keep it civil in here. If you're not going to offer beneficial info and just bash people, i WILL delete your posts and possibly worse. I hope it doesn't have to come to that. Thanks
Old Dec 3, 2008 | 02:48 PM
halocore's Avatar
my buddy almost brough a civic from a guy that claims to know everything about honda, and he was telling my buddy and me that he's running a gsr ecu in his civic and it gives him about 20hp to the wheel. I had a good laugh when he told me that. but the point is you shouldn't run ecu not design for your engine, unless you want to wear it down more.
Old Dec 3, 2008 | 04:55 PM
xxwhixx's Avatar
ummm it will run ..... i think a p72 ecu redlines at 8200 ? hope you dont try to run a sohc that high with them dinky *** rods .... boom headshot
Old Dec 3, 2008 | 05:27 PM
94EG8's Avatar
Seagull Management
X2, P28s are commonly used because they're relatively easy to find compared to P72s and P30s and can easily be reprogrammed. Once the ECU is chipped what it was originally designed for becomes irrelevant. Running a stock P72 will not make any more power as others have already stated, it will run rich.
Old Dec 4, 2008 | 05:34 AM
r1ch1e's Avatar
thanks appreciate the help. i never understood ecu's but now i know a little more than before.
Old Dec 4, 2008 | 06:21 AM
dividedas1's Avatar
thats what i was trying to get at... i wasn't knocking the OP because right now i have a stock p28 running my b16 and i hate it. phearable.net is taking next to forever to get my chip to me but eh it runs still just not as good as it should.
all these ecu's are tuned differently because they are all different motors. they have different vtec cross overs, different air/fuel ratios and different redlines. OP i wasn't trying to say the p28 would look for two cams i was just trying to point out that because there are two cams in a GSR the tune is going to be much different then a sohc vtec motor. ya know? and yes i do believe it would be pretty stupid to run a p72 on a sohc motor hoping for power gains. :-/. i am sure all the claims that it makes a good difference are just on the butt dyno. haha if anything i bet a p72 would hurt your cars overall performance
Old Dec 4, 2008 | 06:30 AM
r1ch1e's Avatar
i understood what you said, but i was also just questioning things i didn't know and see if i was wrong. you know what i mean. now i have a better understanding of thing ecu wise. everyone around, not on the site but people i know they are always swapping their ecu back and fourth and i never understood why i know the diff like the redline and vtec crossover but other than that clueless to why they do that.
Old Dec 4, 2008 | 06:43 AM
kojack_0's Avatar
hmmm. i was using a jdm p30 [obd1 b16] on my z6 before, it ran better with than the p28.
but was putting in too much gas, or running lean.
they're both 1.6 so i figured id use a more aggressive fuel curve.
but then i ended up selling the car.
Old Dec 4, 2008 | 06:46 AM
b18c1ej8's Avatar
also dont forget that the p72 has the IABs for the GSR and no d series motor has IABS so you might want to take that into consideration
DanDaMan559
Jun 3, 2011 12:10 PM
tmar253
Nov 28, 2006 09:39 PM
92TypeR
Nov 27, 2002 11:11 AM
