Key is stuck in ignition....
My key has been intermittently getting stuck in the ignition. A quick disconnect of the battery allows me to turn it all the way off and take the key out. I have researched the problem on google first and came across
http://groups.google.ca/group/rec.au...541bd678be242c
but slamming the shift up does not fix the problem. I then proceeded to open up the haynes repair manual and on 12-23 there is a wiring diagram for the Shift lock solenoid, key interlock solenoid, and Shift lock circuit. I thought it might have something to do with either the key interlock switch or the gear select switch. I then did a google search on honda del sol gear select switch and got back "Neutral Safety Switch." It is 65 bucks and I am not sure that is the problem. Can anyone help?
JuneBugDrfter
Nov 30, 2013 07:57 AM
I hope someone finds a solution to this!
