what year engine and tranny is this???
i bought a jdm f22b engine and tranny for my 96 accord lx. im trying to figure out what year car it came out of. the crank sensor was part of the distributor, not by the oil pump. it has an internal coil distributor. has the automatic gear position switch mounted on the end of the tranny and not by the shifter. is this engine and tranny out of a 93 or earlier accord?? if i post the serial number off the engine and tranny is there any way someone could run the numbers to see what year car it came out of??
Well, it is certainly of JDM origin (Position switch trans mounted)
And I suspect it is OBD1 pre 1994 (Dist mounted TDC sensor)*
But perhaps the numbers will shed some light.
*verified via Honda Parts catalog
USDM went to Oil Pump mounted TDC Sensor for the 1994 model year. I would suspect Honda followed suit for JDM units as well (why build two versions of the same thing?)
P
P
This is going to really confuse things... The MPJA Prefix calls out as a Honda Odyssey 1995 thru 1998 Model year.
Refer:
Honda Odysse MPJA K9100A-S Banner Kit ODYSSEY 1995-1997, Transmission code MPJA, 3 shaft 1995-1997 $144.96
This kit includes all paper and rubber products, o-rings seals, metal clad seals, gaskets and clutch frictions (clutch steels kit not included). Actual parts varies by transmission type.
Honda Odysse MPJA K9100A-9A Steel Clutch Kit 1995-1997, Transmission code MPJA, 3 shaft, Clutch OD 120mm 1995-1997 $59.34
This kit includes all clutch steels. Actual steels vary by transmission type.
Honda Odysse MPJAK9100A-SBanner Kit ODYSSEY 1998, Transmission code MDWA, 3 shaft1998
This kit includes all paper and rubber products, o-rings seals, metal clad seals, gaskets and clutch frictions (clutch steels kit not included). Actual parts varies by transmission type.Honda Odysse MPJAK9100A-9ASteel Clutch Kit 1998, Transmission code MDWA, 3 shaft, Clutch OD 116 120mm1998
Honda Odysse MPJA H 21Torque Converter 4 cylinder 1998 $100.00 $221.30
Dia. 10.875" Pilot .945" dome Hub 1.532" with 38 teeth, mount ring 8 holes , 22 spline, Code P5M, 5M, EA & GA, metal stamp "4", "M" by pilot 114 tooth ring gear, step on bowl beneath dimples. Remanufactured & tested in USA, to ensure the correct part please provide code off original torque converter at time of the order. These torque converters have a 90-day material & workmanship warranty.
Sourse: http://www.drivetrain.com/honda_dt.h...0Odysse%20MPJA
I don't recognize the engine numbers...
P
Refer:
$144.96
$59.34
P
Most Makers build THREE versions of the same model, USDM, JDM and General Export.
Those numbers wont help, Japanese parts shops do not use them at all. Look under the head under the distributor end where the tranny meats the engine, see if you can read the engine type on a flat spot on the block. The front of the block, not actually under the dizzy. It may only show F22B???
F22B were in the Odyssey, Accord and Prelude JDM's. Upper 90's. OBDI in Japan, OBDII started in 2000.
MPJA, first gen Odyssey, RA1.
yeah i put in my original post that it is a jdm f22b. i was wondering if it had come out of an older odyssey. as for the stamp on the head i will try and take a picture of it later tonight. thanks guys
Would anyone happen to know the gear ratios and final drive in this unit?
Driveline section seems to be full of B/D series, and the Ridgeline/CRV/Odyssey board is a bit of a quagmire.
2.705 1
1.535 2
1.057 3
0.750 4
4.428 final
4th gear 195/60 R15
70mph = 3227 rpm
80mph = 3688 rpm
The rpms are spot on. Not too thrilled as I was just looking for a replacement A/T but it sure pulls off the line quickly. But the cruising rpm is just a tad high for the B1, meh. We'll see how the MPGs are effected.
nickoz
Jan 16, 2008 08:53 PM
