Thermostat Sensor???
i was putting a new Si harness on my car and i noticed i was missing a plug for the thermostat sensor...the motor came out of a eg hatch so im not sure if it is supposed to even hook up? any help is appreciated! thanks h-t!
Why would you be putting an EG harness on an EF? Do you have a swap?
EDIT: What motor is it and what model / trim level is your car? What Si harness is it? 88-91 or 92-95?
on your old engine the coolant fan switch was on the back of the block. on the eg it is on the thermostat housing. you have to extend the wires from the back of the block to the thermostat area.
riceboyEFsi
Jun 6, 2003 07:53 AM
