ZC in a 95 dx civic?
Old Aug 1, 2002 | 09:59 PM
Trevor's Avatar
Default ZC in a 95 dx civic?
What is needed? Anyone out there have one?
Thanks for any help.
Trevor
Old Aug 1, 2002 | 10:20 PM
blufke's Avatar
Default Re: ZC in a 95 dx civic? (CR-XSI)
my friend has one in his crx si. its nice cuz he just needed the longblock. its got good hp but you really should consider bseries motors. you can get a b18b swap fairly cheap and its great to build off of. and check hasport.com. they may have info on that swap too if youre set on it.
Old Aug 3, 2002 | 03:02 AM
Mista Bone's Avatar
D Tranny Guru
is the ZC a OBD-0 or OBD-1 motor?
Easier just to get a D16Z6 swap.
Old Aug 3, 2002 | 03:03 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: ZC in a 95 dx civic? (Mista Bone)
Seriously.......
Why, so you can have 10 more HP over a SOHC VTEC???
Old Aug 3, 2002 | 03:23 AM
RR98DX's Avatar
Default Re: ZC in a 95 dx civic? (B18C-EJ1)
Seriously.......
the motor isn't that bad... and its 29 hp more than his DX motor, bolts right in and with out having to wire vtec...
i did it in my EG, i talked about the swap here
https://honda-tech.com/zerothread?id=231252 > scroll down till you see the pics...
i wish honda-tech was more constructive instead of every post being waisted on newbie slaying...
[Modified by RR98DX, 4:24 AM 8/3/2002]
Old Aug 3, 2002 | 03:37 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: ZC in a 95 dx civic? (RR98DX)
Well,
I don't know where Trevor is from, but if he lives in CA, and puts a ZC in his DX, the smog ref will fail him on the spot.
Sure, ZC engines are cheap, and he can re-use his DX tranny, but honestly, the gains are just not worth it in my book.
That's just me tho.
If I were doing it, I'd find a nice 94-95 LS donor at the local JY or similar, and swap that in.
1- It fits in with no probs
2- No extra wiring needs to be done
3- There are a TON of aftermarket parts available
4- It has more torque and HP than a ZC
5- It can be SMOG legal
But again, that's just me.
94hbdx
Jun 9, 2011 09:19 PM
lil_laoboi_904
Apr 26, 2008 01:15 PM
extreme90civic
Sep 4, 2005 11:30 PM
jdmhondacrx
Mar 16, 2003 11:28 PM
bigcrxhf62hp
Jun 25, 2002 11:26 AM
95, dx, zc
