Transmission issues GSR
when i put my car into first gear, as o disengage the clutch i feel the stick slightly move when i let off the clutch like normal. When i EASE off of the clutch the clutch does not move, i am assuming it could be the mount on the passenger side of the tranni.... ALSO my tranni fluid was half full and i refilled with 10-30 temporarily..... slight grind sometimes.... my question is, if i drive this very carefully.....how long do you think it will last? i am on a business trip 100 miles from home..... i need to make it back.... LMK....thanks!
I race (on a 3/8 oval track) my integra GSR with 10W30 engine oil in the transmission. I've never seen an issue with using it...should be fine for only 100 miles. You might want to look into the reason why it was half full...good luck!
kordenbrock motorsports
May 31, 2006 06:53 AM
MiraiZ
Aug 12, 2003 06:18 PM
