TPS question
Old Dec 2, 2008 | 04:25 PM
jdmkid_82's Avatar
Default TPS question
On a d16z6 can the TPS voltage still be off with out throwing a code?
Old Dec 2, 2008 | 04:42 PM
IhateworkingoncaRs's Avatar
Yes, on obd1 vehicles, unless the sensors are completely dead, it won't throw a code.
Old Dec 2, 2008 | 04:56 PM
jdmkid_82's Avatar
well i probed the mid wire (red/blue) and i got 1.8 closed and then a woping 8.0 wot? but i dont have a code tho..but if i unplug the connector then it will
Old Dec 2, 2008 | 05:19 PM
your voltage readings should be .5 to 4.5 volts. It has been awhile since i tested a tps on the d series but your readings definitely don't look right. If you unplug any sensor, you'll get a code. Why are you suspecting the tps?
streetsold6teeny8
Mar 24, 2012 06:46 PM
crusto2k3
Dec 1, 2008 02:14 PM
ALLshowNOgoLS
May 4, 2006 02:19 PM
psegs80
Jul 15, 2005 05:07 AM
