Lighting problem 94 EX
Old Dec 2, 2008 | 02:50 PM
jimmy o.'s Avatar
Default Lighting problem 94 EX
I am having some sort of electrical problem with my car one of the lowbeams do not work (driver side) and one of the turn signals do not work (pass side front) and the corner light do not light up at all the driver side front signal still works tho have no idea whats going on any ideas or possible quick solutions need this fixed asap
Old Dec 2, 2008 | 04:27 PM
jimmy o.'s Avatar
could it be a bad switch? gonna try that if i get no help here and i will go from there
also i replaced the bulbs that didnt work
Old Dec 2, 2008 | 04:45 PM
slacks's Avatar
check for any fuses that could be blown then look around for any short in the wiring that there might be
Old Dec 2, 2008 | 08:35 PM
jimmy o.'s Avatar
bump
Old Dec 3, 2008 | 07:08 AM
jimmy o.'s Avatar
UPDATE
headlights are now working
still no corners tho
Old Dec 3, 2008 | 08:10 AM
jimmy o.'s Avatar
replaced switch still nothing i dont think any fuses are blown wtf is goin on here still no help
Old Dec 3, 2008 | 08:33 AM
jimmy o.'s Avatar
the red wire with the black stripe on the corner light pigtail has no continuity in the curcuit and the passenger side has no power going to it at all where does that wire run to where is the fuse for them its not marked on the box
Update no blown fuses
Old Dec 3, 2008 | 09:34 AM
jimmy o.'s Avatar
have no idea whats wrong i give up guess its time to have someone else fix this bs
Old Dec 3, 2008 | 12:20 PM
jimmy o.'s Avatar
come on look this poor honda it wants to be fixed someone help me help it lol
Old Dec 3, 2008 | 04:18 PM
jimmy o.'s Avatar
ttmft
Old Dec 3, 2008 | 04:43 PM
gsrhatch2356's Avatar
Ok, so you dont have any corner lights right? I mean that you have fixed your other problems right?
first I would start to make sure that you have voltage at 19 under the dash just make sure that the lights are on or you wont see voltage there and you will be running around in circles. if you have voltage there then you can pretty much eliminate everything in the top half of the circut. really all that is left is from the fuse box to the corner lights. start there and I will check back to see if you have made any progress
Old Dec 3, 2008 | 06:39 PM
jimmy o.'s Avatar
thank you finally some good help but no my pass side front blinker still dosent work it blinks real fast (on the dash and the rear) all i fixed was the headlight. I will check it out tommorow thanks its too damn cold lol
Old Dec 6, 2008 | 09:56 AM
jimmy o.'s Avatar
i think i figured it out im thinkin it is the pigtails as im able to pickup voltage at the pigtail but i have to really push on it then it will pick up voltage around 11.7 does this sound like the culprit to you guys
Old Dec 6, 2008 | 10:19 AM
jimmy o.'s Avatar
it was the pigtails i ran a wire to a jumper wire to the bulb holder hooked it up and it came on (both sides) guess its time to go parts hunting lol
Old Dec 6, 2008 | 07:53 PM
well congrats, and if you have any more problems then just pm me and I will try to help
Old Dec 7, 2008 | 06:20 PM
jimmy o.'s Avatar
thanks they are workin good now no problems at all now
teggyluva90
Aug 27, 2013 04:45 PM
jemdogs
Honda Civic (2001 - 2005)
Feb 20, 2011 10:21 PM
thecruzs2007@yahoo.com
Sep 12, 2009 11:02 PM
OMG naD16 lol
Dec 13, 2006 09:19 AM
