MSD sport compact ingitiong box, blaster coil, civic distributor - $165 (boston)
this is a msd sci ignition set up that can be used with any sport compact setup. i was using it on my civic. will include a d16z6 distributor setup to run the msd system. will work great with any 92-95 civic sohc vtec setup. or modifly your distributor and use with any car. this set up is an easy install. just run 2 or 3 wires. msd box also has optional tach output and rpm redline pill inputs.
included
MSD sci ignition box
92-95 civic d16z6 distrobutor (no internal coil) set up for msd
93 accord external coil cap
cap to coil wire. (needs new boot but works good)
MSD blaster 2 coil with mounting bracket.
ill sell entire setup for $110 if u include a good working d16z6 distributor.
included
93solcontender
Mar 9, 2003 02:33 AM
