FS: 94 GSR Swap-MN
I just bought this swap and have decided to go another route with my eg. Its a 94 GSR swap (longblock/trans came out of the same car) with papers. VIN: JH4DC2384RS005708
I have not dropped this swap in so Im unsure of its conditions. The swap is going to be sold as is and there is no warranty on this. It will come with the following.
Longblock/trans/starter/alternator/fly/clutch/etc
Both Axles
OBD2A ECU
Shift Linkage with shifter
Wire harness
3 mounts (driver/pass/rear mounts)
DC 4-1 SS header
Hoses
and a lot of misc things...
Its pretty much everything you need to swap into your civic or integra.
Things that may need to be looked at is..
Motor
- either the head gasket or the cam seal is leaking oil.
- one of the bolts on the head is broke
- distributor is spliced to the wire harness
Im looking for $1500 FIRM so if you're not interested or dont have the money then please go troll somewhere else. No trades as I already bought another swap.
Both Axles
OBD2A ECU
Wire harness
DC 4-1 SS header
Hoses
Motor
