Time Belt Differences??
Old Dec 2, 2008 | 12:05 PM
jksmith's Avatar
Default Time Belt Differences??
i recently bought a fully assembled built block, basically everything brand new...but i dont know what kind of water pump it has on it, so i basically need to know if there is a difference between LS, GSR, B16 timing belts??
Old Dec 2, 2008 | 01:07 PM
trustdestruction's Avatar
I don't know the exact differences or which ones are different, but...
If the cam gears on one motor have a different amount of teeth than the other motor, they use different timing belts. So, it might be easier to find out how many teeth are on each motor's cam gear.
Old Dec 2, 2008 | 01:49 PM
jfruauff's Avatar
look on the water pump gear and there is a number thats how many teeth is has. Post up at # and someone will tell you what pump you have or go to store and have them pull all 3 off shelf and find the same #. You need to match belt to pump
Genesis777
Jun 13, 2017 06:40 AM
Swifty92
Feb 17, 2011 12:17 PM
SuperSteve737
Apr 4, 2006 03:33 PM
only4cylinders
Apr 8, 2005 12:18 PM
GDM Z28
10
Aug 19, 2003 10:32 AM
