Swap Question?
Old Dec 2, 2008 | 10:29 AM
EgK2o09's Avatar
Icon2 Swap Question?
Im in the middle of taking out my h22a out of my 94 Accord. I recently picked up a f22b SOCH vtec. I have been researching on what i need to change like the distributor.I just wanted to know if i can use the h22a distributor or just the f22b1 that comes in the car? Also i wanted to know if anything else would have to be changed??? Thank you. Any help is appreciated.
Old Dec 2, 2008 | 10:55 AM
Duane_in_Japan's Avatar
Please do a search and use the FAQ section of the forum. Here is a recent link that may help a little but not sure.
reply #3,
https://honda-tech.com/forums/showth...5#post36575015
Old Dec 2, 2008 | 11:03 AM
EgK2o09's Avatar
reply #3,
thanks but that didnt answer my question. And I did search everything iv'e seen has been telling me h23a distributor works. I just wanted to know if the h22a distributor would work... thank you fow your time tho.
Old Dec 2, 2008 | 11:14 AM
OK, open both distrubutors and see if they both have the same profile on the reluctors, I will assume that they both have the same number of wires coming out of them.
If there are three sensors inside then they should be the same shape with the same number of teeth on them.
Also make sure the two dizzys are indexed the same, when the lines on the bottom of the housing and the drive gear are lined up, then they both should point in the same direction, I am talking about the rotor.
NukeeZoid
May 24, 2006 09:05 PM
jdmengine
Sep 29, 2003 04:29 PM
BigBank420
Oct 21, 2002 03:47 AM
EVO_S4
Feb 15, 2002 12:21 PM
