sohc to dohc
Old Aug 1, 2002 | 07:57 PM
poz15's Avatar
Default sohc to dohc
my friend said that changing my 97 civic ex from a sohc to a dohc would add about 25-30 hp is this true or just bs thanks
Old Aug 1, 2002 | 08:02 PM
dirtySOHC's's Avatar
Default Re: sohc to dohc (poz15)
you talkin about a swap.......it depends on wat motor.
damn man........read the board. there are hybrid gods in here.....and tons of information.
Old Aug 1, 2002 | 11:27 PM
Koori's Avatar
Default Re: sohc to dohc (dirtySOHC's)
Hmm.. Well, it sounds to me that you're doing a direct sohc to dohc conversion on your stock D16Y8. Umm, you better put your hip boots on cuz someone is waist high in **** talking. As for a b series swap.. A B16A (99-00 Si) would put you about 30hp higher at the crank. The B18's (A, B, C5) are the ****. You could be pushing anywhere from 160 to 180hp range..
Old Aug 1, 2002 | 11:37 PM
poison's Avatar
Default Re: sohc to dohc (Hadji)
Well said
That's a pretty broad statement, but if he's talking about a motor swap, then yes, as for putting dohc on a sohc block, unless it's a ZC -- not going to happen.
HTH
Old Aug 2, 2002 | 01:49 AM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
have a beer well said...im getting my swap also (b16b)...cant go wrong with a b series motor...i think u should just get a jdm gsr...my cousin has that and i got spanked in 1st gear when i raced him...to get my point across..... if u want high end, get a jdm gsr...if u want ur car quick at the start, get a b16a2...the gsr kinda lags but will spank u in high end...good luck
Old Aug 2, 2002 | 05:25 AM
Civic1992DX's Avatar
Default Re: sohc to dohc (PEN15teamJDM)
GSR engine will ALWAYS spank B16 (considering them in the same type of car)! More torque = more pull off the line. Even my B18B1 pulls harder than B16 off the line.
Old Aug 2, 2002 | 05:03 PM
mugenracer's Avatar
Default Re: sohc to dohc (Civic1992DX)
so so true
Old Aug 2, 2002 | 08:19 PM
slomofo's Avatar
GDD Member
Wiring a B18C1 into a civic is a bit difficult though.
Old Aug 2, 2002 | 08:33 PM
Default Re: sohc to dohc (slomofo)
slowmofo, you made me laugh! JDM 3-1 header, Geo Metro type R
I had 1.5 bottles of wine & it's FUNNY!!!! Hahaha!!!!
Peace...
Yuri K
Mark80
May 14, 2006 08:01 PM
JDMorgan
Mar 8, 2004 07:05 AM
s0liDyNe
43
Oct 4, 2002 08:35 PM
gubo22
13
Jul 19, 2001 02:40 PM
