Suspension & Brakes Theory, alignment, spring rates....
What Calipers Do i have
Old Dec 1, 2008 | 09:22 PM
friscohead's Avatar
Default What Calipers Do i have
Hey. i just purchased a full front and rear GSR brake conversion. or so i thought. after a little research i found out that the front knuckles, calipers, and rotors are off of a 93-95 civic ex from the casting numbers on the calipers (16CL14VN). i want to know what the rear trailing arms are off of, and the casting numbers on the calipers are both 7CLP13S. i tried aearching and searching and i couldnt find anything. can someone please help me out? also, i want to know what mc/bb i have. on the sticker at the top, it says NISSIN NM-260V
Old Dec 8, 2008 | 11:55 AM
Katman's Avatar
93-95 civic EX's (w/ABS which all EX's came with) use the same exact brakes as a GSR (10.3" rotor).
An easy way to tell is by measuring your rotor. If it's slightly over 10 inches in diameter, you're all good, you have GSR sized brakes.
As for your MC/Booster....
What number is stamped on teh side of the MC? 15/16 or 1? here's where to look:
If you have a 15/16" or 1" MC you have the bigger integra/EX MC - which is good.
Which booster does yours closely resemble?
If the 2 boosters on the left resemble yours, you have the (bigger) integra/civic EX booster which is good.
The booster on the far right is a wimpy civic (non-abs) booster - hope you don't have this one!
Old Dec 10, 2008 | 02:59 AM
E.Honda's Avatar
All ex civics did not come with ABS as stated above. It was an option on 93-94. Standard on the 4 door.
Bobby_Budds
Suspension & Brakes
57
Jan 22, 2016 01:24 PM
LoneAutosport
Suspension & Brakes
Nov 25, 2009 08:19 PM
NinetyTwoHB
10
Feb 12, 2005 11:31 PM
hybrid901
Feb 13, 2003 01:12 PM
