b18a1 swap trouble
Old Dec 1, 2008 | 08:18 PM
'91teg's Avatar
Icon3 b18a1 swap trouble
hey i got 93 civic vx im tryin to put a b18a1 block with b16 vtec head into it.
got the motor in and plugged up and hoses connected. problem is, motor just wont turn over..fuel is gettin through and i believe im gettin spark, but no luck.
can a pro help me?
Old Dec 1, 2008 | 08:27 PM
EFRue57's Avatar
is it cranking and just not firing up or is it not even cranking? if it's not even cranking the first thing i would check is the starter. if you can test it and it turns out okay i guess next would be wiring.
if it's cranking and not firing up double check your fuel delivery and spark. this is an easy check by simply unplugging one of the injectors and have some one crank it over for a sec to see if fuel squirts out.
same concept with the spark. just pull one of the plugs and then put it back in the wire then have someone crank while you try to jump spark from the plug to the engine bay somewhere. i usually jumped it to the nut on the shock tower. if you have spark next i would check timing.
Old Dec 1, 2008 | 08:28 PM
'91teg's Avatar
yeah its crankin..and yep injectors r shootin fuel, spark plugs r gettin spark, and even re-adjusted the timing..
Old Dec 1, 2008 | 08:48 PM
iwanttokillgod's Avatar
only things needed to start your motor fuel spark which u claim to have both and compression so maybe your motor is ****ed check for compression
Old Dec 1, 2008 | 08:55 PM
EFRue57's Avatar
not entirely correct.....you need timing also and correct wiring. and not just wiring to the dist. and plugs but to all sensors as well.
Old Dec 1, 2008 | 09:02 PM
'91teg's Avatar
yeah im thinkin compression..ill get that compression tester ish and figure that out for sure..thanx fellas
xLaziestLa0b0ix
Mar 6, 2012 06:38 PM
A2gt35r
Sep 30, 2007 06:26 PM
chu77
Sep 11, 2006 08:10 PM
shyxboy
10
May 14, 2005 07:28 AM
mustninty
17
May 24, 2004 12:52 PM
