CHEAP Full motor setup, Turbo kit too CHEAP
Old Dec 1, 2008 | 06:31 PM
JdMhEaD's Avatar
Default CHEAP Full motor setup, Turbo kit too CHEAP
Im selling it all. This price is crack head pricing. you cant buy a JDM ITR swap and make it run for this price. $5000 takes it all. ALL.
Motor:
LS Bottom end
Golden Eagle Sleeves 84mm
Endyn Pistons
Eagle Rods
LS crank
ARP headstuds
B16 head
ITR valve train
B16 Cams
Crower cam gears
Shaved Valve cover
Edelbrock Victor X intake manifold
Edelbrock Throttle Body
RC750cc Injectors
Morroso oil pan
GM 3 bar map
Turbo kit:
Inline Pro t4 manifold
Turbosmart 38mm WG
t4/t67 Precision turbo .88a/r exhaust .70 cold side
3 inch down pipe (vband)
INline pro intercooler kit
HKS BOV
Oil Lines
TurboXS Dual stage Boost controller
Trans/axles:
B16 Non LSD,
PERFECT!!! BUTTER SMOOTH!!! SMOOHEST TRANSMISSION I HAVE EVER DRIVEN
Only problem is the bolt hole right on top of the trans (by the engine code) is broken, it does not effect anything on the transmission or motor.
Stock OE replacement axles included. Also have one spare.
Electronics:
Hondata S300 In a p28 with data cable
THIS IS A DROP IN AND GO SWAP!!!!!! JUST PUT YOUR HARNESS ON IT!!! THATS IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! $5000 $5000 $5000!!!!!!!!!! Axles, trans, shift linkage, EVERYTHING!!!!!!!!!!!!!!!!!!!!!!!!
On top of it being drop in and go, in my car it ran 11.50 @123mph made 380whp and 270tq at 14psi on pump gas.
On race gas it made 389whp @11psi and 430whp @17psi
The turbo drain needs to be reworked. It was backing up and causing some smoke at idle only. Not any smoking while driving or while WOT. Only at idle. It works great, has minimal shaft play (typical for journal type turbos when no oil is running through it).
$5000, 5 stacks, 5Grand,
Its a killer setup, has TONS of vouches, many people have driven, ridden, seen it and they all know its a killer reliable setup. I drive it every day. gets great gas mileage, i averaged 31mpg on my last trip, which was 550miles exactly...then i ran 11.50@123mph and drove it home.
Please pm me for any questions. No negative remarks at all. I know it is christmas time, but i also know someone wants this really bad.
Will trade for a k20 or k24 motor/dropout from a rsx/tsx + cash on your end.
And dont mess with me, im no fool.
K20a2 swap at most is $3000, this is a $5000 motor/turbo kit..have 2k cash ready.
Will ship at buyers expense.
Michael Lee
Birmingham, Alabama
Old Dec 2, 2008 | 04:35 AM
JdMhEaD's Avatar
BUMP!!!
Old Jan 11, 2009 | 03:32 PM
keep_h8n's Avatar
Default Re: CHEAP Full motor setup, Turbo kit too CHEAP
Ever sell this?
Old Jan 11, 2009 | 04:04 PM
JdMhEaD's Avatar
I sold the turbo kit. still have the motor in my car running NA. perfect still
JdMhEaD's Avatar
actually trying to buy another kit...if someone doesnt buy it!
Old Jan 11, 2009 | 04:37 PM
shocker911's Avatar
just asking what would you want for the motor?
Old Jan 11, 2009 | 05:17 PM
JdMhEaD's Avatar
$3000 with motor and S300 and $3500 with motor, trans, s300, axles, etc (full swap basically)
Old Jan 11, 2009 | 08:12 PM
EFSedan#6's Avatar
bump for looking.
1_SiK_Eg
Mid-Atlantic (Sales)
Oct 7, 2011 03:58 AM
JdMhEaD
Dec 2, 2008 05:52 AM
just2.0vtec
Jan 21, 2008 08:53 PM
dazcivic
Aug 15, 2007 10:59 AM
Corrado
Dec 24, 2005 12:35 AM
