lsvtec rpms goin crazy
Old Dec 1, 2008 | 12:08 PM
biggoofy's Avatar
Icon3 lsvtec rpms goin crazy
i have a 94 lsvtec turbo and i was drivin from fla to nc and my tach started goin crazy but only after i had discovered a huge crack in my turbo manifold any help is welcome im on a low budget and this is my dd the manifold is being fixed but wat would cause the needle and car to go crazy it wont run right at all
Old Dec 1, 2008 | 12:23 PM
MHBb16CRX's Avatar
check the knock sensor & wire for the sensor. Thats wat made my b16a do that. also check the dizy.
Mo
Old Dec 1, 2008 | 12:46 PM
biggoofy's Avatar
i was thinkin it might be the cap i had a problem with wires staying on i think im gonna pick up a new cap and rotor
Old Dec 1, 2008 | 03:21 PM
biggoofy's Avatar
need help please!!!!!!!!!!!!!!!!
Old Dec 1, 2008 | 04:42 PM
slaminsam's Avatar
probably the icm. Thats what caused my tach to go crazy and start randomly breaking up.
Old Dec 1, 2008 | 05:22 PM
biggoofy's Avatar
where is the icm located
Old Dec 1, 2008 | 05:30 PM
JDM CERTiFiED's Avatar
maybe the tps sensor
Old Dec 1, 2008 | 05:33 PM
biggoofy's Avatar
tps is good
Old Dec 1, 2008 | 06:19 PM
slaminsam's Avatar
the icm or ignition control module is located inside the distributor.
Old Dec 1, 2008 | 06:21 PM
biggoofy's Avatar
so new dizzy?
Old Dec 1, 2008 | 07:01 PM
slaminsam's Avatar
You can just replace the icm it is available separately since your on the cheap. A dizzy can be quite expensive if you go factory.
Old Dec 1, 2008 | 07:04 PM
biggoofy's Avatar
ok sounds good i looked all i have to do is resodder?
Old Dec 2, 2008 | 03:19 AM
slaminsam's Avatar
Nope you dont even have to do that. It is like two bolts and 4 wires to unplug. Here is a lil guide to testing a no spark condition but it shows you in detail what you need to know.
http://www.team-integra.net/sections...ArticleID=1113
Old Dec 2, 2008 | 12:59 PM
biggoofy's Avatar
awesome thanks alot man so heres the thing i belive i have spark because it runs but dies but the tach needle and engine go nuts so im kinda lost
Old Dec 2, 2008 | 01:24 PM
bfatdaintegra's Avatar
Icon6 your ls vetc
what kind of ecu are u running, also who wired up te car it could be a wiring issue,if u tried everything else swap out the harness my old da was doing same **** but not the tach. i swapped it out and it was all gravy
Old Dec 2, 2008 | 01:29 PM
b16vt3c's Avatar
you should check the wire
Old Dec 2, 2008 | 04:57 PM
slaminsam's Avatar
Yeah Im sure you still have spark... So did I. It just didn't run good at all and would misfire at different rpms. I ended up putting a whole new dizzy on and it fixed my problems. That article was just for reference pictures. Do you possibly have any codes in the ecu?
enot767
Oct 10, 2008 01:18 PM
90efmexstyle
Jun 25, 2008 07:44 PM
ls19integra95
Aug 7, 2007 07:58 AM
FrankEXsteiN
Sep 6, 2002 11:31 AM
