Problems after wiring fog lights
ok well as some of you read my other thread on wiring fog lights in my 2000 civic ex coupe and after trying a few different spots for the main feed for the fog light wiring after figuring the wiring out i have a problem with the illumination on the power mirror adjustment, sunroof switc,h cruise control switch, cluster illumination, none of the lights come on when u turn the headlights on is there a fuse just for thos for switch illumintaion or did i fry sumthing? also the door chime for the key in the ignition dosnt chime anymore
Is there anything else that isnt working properly?
I cant find a fuse for the "door chime" in my service manual, It may have another name or share a fuse for something else.
You could try the Accesory Fuse, Its number 27. UnderDash and is a 10A fuse.
i checked all the fuses physically and with a test light there all ok i also noticed that the intermitant on the wipers dosnt work unless the headlights are on im stumped pleas help
EGdope
Jun 26, 2012 09:21 AM
