question about f22 with h23 head?
Old Dec 1, 2008 | 11:10 AM
cjmurillo's Avatar
Default question about f22 with h23 head?
i have the parts laying around and was wondering if it would be worth putting the h23 head on the f22 block and would there be any noticeable power gain?....my current motor has a lot of miles so looking to swap it out with something....
Old Dec 1, 2008 | 06:41 PM
Duane_in_Japan's Avatar
Sorry friend, you are going to need to do some searching in the search section and also go through the STICKY section and check out the FAQs that deal with swaps, look at the top area of the forum. You might get lucky if someone has done this exact swap, head only. Go to the parts store and ask to see both head gaskets and compare them. There are other issues like compression ratio and deck height between the two engines.
Old Dec 2, 2008 | 10:32 AM
jweller's Avatar
yes, it bolts right up. Worth is another question altogether. Now go read these.
https://honda-tech.com/zerothread?id=1482111
https://honda-tech.com/zerothread?id=1069869
https://honda-tech.com/zerothread?id=776837
https://honda-tech.com/zerothread?id=1046336
come back, ask more questions.
michaelprice83
Sep 22, 2008 09:28 AM
f23__
May 7, 2007 10:40 AM
n8dogg
Apr 12, 2005 01:31 PM
93redlude
Aug 15, 2004 04:16 PM
IcePenguin
Apr 6, 2004 07:24 AM
