Compression numbers for Type-S bottom end???
Old Dec 1, 2008 | 10:32 AM
c1v1c98's Avatar
Default Compression numbers for Type-S bottom end???
I've got a 97 Type-S bottom end (11:1 cr) with a OBD1 head. What compression numbers should I be seeing when I do a compression test?
I just bought a compression tester and I need to know what numbers I should be within.
Also, Should the engine be warm or cold?
Old Dec 1, 2008 | 10:39 AM
98vtec's Avatar
moderator emeritus
no way for us to tell you. different gauges will read the numbers differently. The key is having all cylinders within a close proximity.
PirateMcFred's Avatar
At sea level with stock cams my Type-S block/OBD1 H22A1 head made about 245psi in each cylinder years ago. But remember that every compresion tester will be different and consistancy between cylinders is probably more important.
Pirate
*damn, Blake beat me to it*
Old Dec 1, 2008 | 10:41 AM
98vtec's Avatar
moderator emeritus
aaarrrggggg!!!
Old Dec 1, 2008 | 12:38 PM
mattsnooz's Avatar
I'd suggest doing it when its warm. Your car runs mostly while warmed up. Anywhere in around 200 is average. As they both stated (almost in a duet) as long as they are withen 10 psi (10 is still a bit off in my personal opinion but that wouldn't indicate anything wrong to my knowledge) of eachother, theres nothing to worry about!
Just so you know too, I think you only need to crank the car like 3-4 times (or atleast thats all I had to do to get an accurate reading, but mine also storred the reading)? Some guys here suggested to crank it like 10 times and I never thought anybody had to crank their car that many times to get a reading. After 3 cranks it went up to 187 (on my h23) and even with a few more, It didn't fluctuate much so I'd assume it only takes a couple cranks.
Old Dec 1, 2008 | 02:37 PM
c1v1c98's Avatar
I was in between 260 and 270 all the way across.
As far as how many cranks, it took me at least 5 or 6 to get it up to a constant pressure.
Old Dec 1, 2008 | 02:53 PM
Sounds good to me.
Old Dec 1, 2008 | 04:19 PM
c1v1c98's Avatar
Thanks for the input guys.
speed_demon018
Jul 22, 2010 12:02 PM
Convert
Jan 28, 2009 05:44 PM
patriot
13
Aug 23, 2008 03:19 PM
builtprelude
Jan 22, 2004 10:49 PM
Norcalstoppy
Nov 21, 2002 12:55 PM
