93 civic hatchback has jerk when turning
Old Dec 1, 2008 | 10:29 AM
metalcitymc's Avatar
Default 93 civic hatchback has jerk when turning
I would greatly appreciate any help with this one. this is my first front wheel drive car and i'm at a loss. The car is a 93 hatchback with the smallest motor and no options no power steering, 5 speed. there is no obvious play in any of the tie rods or joints and i just had the front tires checked and balanced. the car will drive fine for 30 minutes at a time then feel like i'm losing a wheel for ten min then go back to normal. any Ideas?????
Old Dec 1, 2008 | 10:46 AM
90_EX_Civic's Avatar
did you check your wheelbearings yet?
Old Dec 1, 2008 | 11:23 AM
cant find any play anywhere including wheel bearings
Old Dec 1, 2008 | 11:33 AM
at what speeds is this happening at?
Old Dec 1, 2008 | 11:41 AM
Mashimaro's Avatar
sounds more like transmission problems if anything. was this car modified when you bought it?
Old Dec 1, 2008 | 11:47 AM
it could be few things. the only other thing i could guess to think would be the rubber bushing that acts like a balancer that is on your axles. but you can't through out the posiablity of it being tranny problems.
Old Dec 1, 2008 | 12:32 PM
instructor74's Avatar
Check both lower ball joints with the car off the ground. lift up on the botom of the tire and see if you have any play. I had one fail this way, it only had play in a vertical motion and had no lateral play. It caused a problm like what you are having.
hcaulfield57
Suspension & Brakes
16
Aug 27, 2017 03:09 PM
White_EG1
24
Jun 21, 2015 09:28 PM
h22-turbo_hatch
10
Jan 8, 2013 12:30 PM
MikesEJ1
12
Mar 18, 2012 06:47 PM
blackccoupe
May 23, 2005 04:19 PM
