Massive End of Project Sale 12/3 (more stuff/updated) K20 added
Old Dec 1, 2008 | 09:43 AM
90dteg's Avatar
Default Massive End of Project Sale 12/3 (more stuff/updated) K20 added
These are all new Honda Parts In Package.
pt# 51306-ST7-000 24mm front sway bar bushings(B16 Del Sol) $10 pr. Reatil $7.20ea.
pt# 30103-P08-003 Tec dizzy rotor (with screw hole) $10 Retail $21.20
pt# 91213-PR3-004 DOHC VTec cam seals(x2) $5ea $9pr Retail $6.85ea
H22 OEM Ignition Wire Set (with coil wire) $50
pt# 91212-P0A-004 H/F series front crank seal $6ea Retail $8.28ea
pt# 52320-S10-003/52321-S10-003 97-01 CRV Rear sway Bar Links $41ea $60pr Retail $55.83ea
pt# 52320-S04-003/52321-S04-003 99-00 Civic Si Rear Sway Bar Links $45ea $70pr Reatil $61.10ea
OEM Honda Audio console(not Honda Acess) $100
OEM Honda eg hatch mud guards $50
That is it for the new stuff, on to the used.
Misc. eg switchs $5ea
New EK factory Honda Fog Light Switch Not in package though $15
B series rear mount (from my RHD front clip) No cracks $20
EG clock (blue lit) $20
EG/Del Sol license plate lens $15pr
Audiobahn 12" Competition Sub New in the box $150
True RHD EG Coin Pocket $10
Real EG Fog Light Switch $10
New Never Installed F22/F23 Vtec cheap header and down pipe $70
Factory EG Accessory Tweeters Used for like 6 months $30pr
Also have (sorry no prictures) a H22 Type SH motor $400. Has no intake manifold, or exhaust. It does need to be rebuilt. The motor spun a rod bearing. Nothing to bad according to the Honda tech that pulled and replaced the motor. It was barely making noise. He said He would have the crank polished and put new bearings in. It was an insurance job so they decided to put a salvage motor in its place. to save money than rebuilding it.
K20Z3 short block Brand new from honda. This does not have a head. it is just the short block brand new (not remaned) $800.
D series 5spd Tranny, mount, clutch and flywheel(93 S model Del Sol) $175
Dseries 5spd starter $40
Del Sol SOHC Shift Linkage $50
eg 5spd D series rear bracket $25
eg D series 5spd rear motor mount $15
eg D series timing cover mount (2 bolt flange)$15
I take cash and Paypal. Paypal add 3%. Can ship parts if you pay shipping fees.
Old Dec 1, 2008 | 11:13 AM
Smokinsax's Avatar
The Boot
looks like some quality stuff here...good luck with the sale
Old Dec 2, 2008 | 03:13 AM
90dteg's Avatar
Thanks
Old Dec 6, 2008 | 05:43 AM
90dteg's Avatar
bump
Verkmiester
Mar 24, 2016 03:23 PM
nomoshing
Suspension & Brakes
Feb 11, 2010 01:47 PM
90dteg
Jan 11, 2009 01:30 PM
bearboy80
Apr 29, 2003 03:48 PM
