Wires cought on fire - need to know where it goes
Old Dec 1, 2008 | 08:15 AM
truevietluv636's Avatar
Default Wires cought on fire - need to know where it goes
i have a 98 civic lx, in the morning i started the car, smoke came up from the engine bay and my cel turned on. i turned off the car and opened the hood, in the main connector on the top left towards the firewall (driver side), the black/yellow small wire was burned. can someone please tell me what that wire is for and where it goes. i looked at it and it goes from inside the car through the firewall and down under the intake manifold. please help, thank you.
Old Dec 1, 2008 | 08:27 AM
steveop's Avatar
wire from the dead end clip??
Old Dec 1, 2008 | 03:43 PM
im not sure which one is the dead end clip, but here's a picture.
Old Dec 1, 2008 | 03:45 PM
i cut the wire because it was already burnt and i didnt want it to keep burning the other wires. anyways, thats right next to the brake master cyl. let me know what it is, i'll probably end up splicing where the wire starts and ends and putting a whole new wire.
Old Dec 1, 2008 | 03:46 PM
v8 integra's Avatar
just curious? wat was ur cel for?
Old Dec 1, 2008 | 04:11 PM
i think it was the o2 sensor... also forgot to mention, when i first started the car and it smoked up, i gassed the car a lil and the speedometer jumped up and down....
Old Dec 1, 2008 | 04:45 PM
someone please help, i have a two hour commute to work with the car every day, need it fixed asap.
Old Dec 1, 2008 | 05:58 PM
when i cut the wire, i check for battery power key on.... on the firewall side had b+, on the engine side did not. hope someone knows something about this.
Old Dec 2, 2008 | 05:37 AM
bump.
Old Dec 2, 2008 | 05:50 PM
v8 integra's Avatar
bump 2tt
Old Dec 2, 2008 | 09:19 PM
INCNTRL4's Avatar
check a helms manual, or something and find out what that wire runs to, i can prolly check tomorrow at work in my work system if no one chimes in.
worst case, cut everything apart and follow it.
Old Dec 3, 2008 | 09:35 AM
streetdrifter94's Avatar
is that a part of your main harness?
Old Dec 3, 2008 | 02:18 PM
crashedaex's Avatar
I have this same exact problem right now...its a bitch...check fuse 15 under the dash...it should be a 7.5A. Your fuse holder is probably melted (mine was) the fuse practically fell out. I cut the wire and ran a new one and i also put in a new fuse box. The problem is still there. It is in the same circuit as the o2, alternator, and vss. I have already replaced the vss. I think it may be the alternator producing too many amps but im not sure. Shoot me a PM.
Old Dec 3, 2008 | 02:31 PM
66fasty's Avatar
i thought black w yellow stripes were switched 12v wires?
Old Dec 3, 2008 | 05:40 PM
ok, fixed the problem. It was a faulty #15 fuse, replaced the fuse, took apart the main harness and pulled out the burnt wire, replaced the wire. car runs fine now...cel still on...
the bad news, somehow through taking apart the main wire harness, i fuked up the obd2. now i cant clear the code... hella gay, so yeah, got work tomorrow so i'll try the obd2 again at work with a better scantool, hopefully my scantool is garbage.
yeah, so now thinking about what happened, i think the alternator is bad, pulling out too much power when it wants and burning the fuse/wire. tired of this piece of **** car so now selling it. lol.
Old Dec 3, 2008 | 08:11 PM
crashedaex's Avatar
also check to see if your wires from the o2 sensors are rubbing on any metal.
Old Dec 3, 2008 | 10:05 PM
i forgot to mention, when my car first smoked up i turned off the ignition... was like wtf and looked under the hood, didnt see where the smoke was comming from.... so turned KEY ON, didnt see anything happening... then IGNITION ON, wires smoked up again.... so yeah, thats why i think its the alternator thats gone bad. nothing happened until i started the car.
i'l check the wires for o2 sensors tomorrow morning.
fcm
Aug 30, 2013 03:30 AM
prelude182
Feb 24, 2011 11:23 AM
90_EX_Civic
Mar 21, 2009 07:59 PM
92_honda_hatch
Sep 28, 2006 09:06 PM
silver hatch
Mar 29, 2005 01:52 PM
