Help Needed ASAP!!! Car wont start
Old Dec 1, 2008 | 04:36 AM
gsrpedro's Avatar
Default Help Needed ASAP!!! Car wont start
my car was throwing code 9 so i replaced the dizzy wit a new one and now the car wont start it has sparks but it wont start i need help!! thanks
Old Dec 1, 2008 | 05:01 AM
94EG8's Avatar
Seagull Management
You sure you didn't get the distributor 180 degrees off?
Old Dec 1, 2008 | 08:16 AM
gsrpedro's Avatar
wut u mean???
Old Dec 1, 2008 | 08:23 AM
mugen92acintls's Avatar
When you put that distributer in, It only goes in one way unless you force it in. When you pushed it onto the head, the part that the cam spins can be upside down (hard to explain w/o being there to show you). Did you get your firing order right (the spark plug wire sequence?)? If you have spark it sounds like you missed something simple.
Old Dec 1, 2008 | 08:40 AM
gsrpedro's Avatar
yea i know the dizzy goes only one way in i did it right but still doesnt start
Old Dec 1, 2008 | 08:47 AM
driveslow's Avatar
ok, the only thing you did differently was change out the dizzy, either a bad dizzy, reseat the spark plug cables, swapp it out with a known good dizzy (or throw your old one back in. I would start there. Did you disconnect anything else while doing this? battery?
Old Dec 1, 2008 | 08:52 AM
gsrpedro's Avatar
no i didnt do anythin else i took the old dizzy out and put the new one in thats all i did
Old Dec 5, 2008 | 09:18 AM
gsrpedro's Avatar
anybody plz i need my car running
Old Dec 5, 2008 | 11:42 AM
94EG8's Avatar
Seagull Management
Perhaps you lost or forgot to install the spring that screws into the top of the coil and supplys power to the cap?
91EF919
Mar 31, 2011 10:15 PM
ilovejdmhoes23
Jan 18, 2007 11:30 PM
fwdftw
52
Sep 5, 2006 11:31 PM
hybridEj6
Jun 25, 2003 10:57 PM
reese
Sep 2, 2002 11:59 PM
