Weak hand brake
Old Nov 30, 2008 | 10:51 PM
Earthbrand's Avatar
Default Weak hand brake
I drive a '97 Prelude SH and the hand brake is very weak. It is almost to the point of sliding down a slope if I don't have it in gear. Now that the snow is about to set in for winter, I was wondering if anyone knew how I can tighten the hand brake or at least where I can find how to do it. Any help would be appreciated.
Old Dec 1, 2008 | 03:24 AM
gsrpedro's Avatar
take out ur center console and take a 12mm wrench and tighten up
Old Dec 1, 2008 | 03:33 AM
shutta's Avatar
lets try to be a bit more elaborate with our answers..
try any of these links to download a service manual to walk you through it
http://www.superhonda.com/forum/f146...online-303151/
http://www.manualnguide.com/download...ce-manual.html
got both of those by searching prelude service manual on Google. I'm sure you can find more. download and browse freely. i'm pretty sure the mechanical side of it is the same for 4th and 5th gens but removing the console will be a little different
Old Dec 1, 2008 | 11:54 AM
teambk8's Avatar
drive backwards with the hand brake up, just make sure to check your brake fluid afterwards.
Old Dec 1, 2008 | 12:51 PM
shutta's Avatar
??. care to elaborate how exactly that works?
Old Dec 2, 2008 | 11:42 AM
teambk8's Avatar
Pull the handbrake up and put the car in reverse, then drive. Its usually better if you hold the brake and gradually apply pressure. I don't know HOW it work mechanically, I just know that my handbrake barely even worked then I drove it in reverse with the handbrake engaged and it started working MUCH better... it was a recommendation by a mechanic friend of mine, I honestly didn't think it was going to work but I was proven wrong, wasn't the first, wont be the last.
Old Dec 2, 2008 | 01:56 PM
shutta's Avatar
hmm.. interesting..
Old Dec 2, 2008 | 03:52 PM
Earthbrand's Avatar
do you mean push the floor brake while reversing then start pulling the handbrake? cuz i dont know how i would do that with a manual...
Old Dec 2, 2008 | 04:54 PM
shutta's Avatar
pull the handbrake, not the foot brake
Old Dec 2, 2008 | 06:17 PM
Crash_Control's Avatar
I am gonna have to try this one when I get my Prelude back.
Old Dec 2, 2008 | 07:05 PM
turnofftheradio's Avatar
I've never heard of that on rear disc brakes. not that you are wrong.
I know on rear drum brakes in reverse, and when the parking brake is applied, the adjuster is supposed to turn the star wheel providing adjustment.
brettnahmann
Feb 24, 2013 06:06 AM
appleyard313
Feb 27, 2007 12:04 PM
BG-Teg
Feb 26, 2007 11:15 AM
1991hondahatchsi
May 26, 2006 05:09 PM
