94 dx obd1 ls swap NEED HELLP 4REAL
hhey well see i have a 94 civic dx with an ls swap ok
so i get the motor and i drop the thing in
evrythings plug and play so i plug evrything up and check all the hoses and see if evrthing ok .
then i go and go get my bateryy lucky i had the fuse box under the hood open for some reson i put the negative terminal and then right when i touch the positive terminal it BLOWS UP THE 50a fuse that goes under the hood in the fuse box
that fuse is the ignition fuse i bolive corect me if im wrong..
im only 17 and ive dunn all the work.. has anny one incounterd this problem let me knoe how u guys resolved it cuz i wanna see if this thing torn on
and i also dont get anny power threw out the hole car NO POWER WHAT so ever no life
IF U KKNOE WHATS WRONG PLSZ HELP>> its my only transpertation,, plz
i need help FROME U GUYS THANKS
get a circuit breaker that's the same amprege rating, put it where that fuse goes. Start pulling fuses one by one and see if it trips the breaker. If the doesn't work start unplugging stuff one by one. You have to go back and check whatever you touched.
then why do u thikn that it blows that fuse ??? have anny idea?? i got me a starter thank god i didnt pay 4 it but imma instal it anny who its brand new.. but why u thikn im blowing up that one ignition 50a fuse uthikn i dont have a good ground i have the tranny one and the one on the head ,,
it's not because you don't have a good ground. Did you fail physics in high school? You blow the fuse because you have something going straight to ground. It means that positive is touching the ground somehow (it's called a short). How hard is that to explain. It could be something defective, or something that's touching, or something that's not hooked up where it's not supposed to be. It's a short to ground, not that you are missing the ground.
i have no clue what that is and how to use it but ill ask my brother umm.. but i was told today that my starter was crosed and thats what cases to blow the fuse?? what u think ??
