how to gain more top need power?
Old Nov 30, 2008 | 06:26 PM
felixjr18's Avatar
Default how to gain more top need power?
ok I'm looking forward to getting some more top end power out of my teg.. its got the b18a1 with all ebay brand components such as header intake downpipe cat exhaust ect.. I bought it this way and looking to swap out with wat ever will perform better than cheap ebay parts. the exhaust will be swapped out ASAP with a custom skunk2 set up but what else would help with some more power in the top end and keep my off the line power band good? I have really good acceleration in low end then it doesn't carry on after 60mph.. any suggestions?
Old Nov 30, 2008 | 06:33 PM
1992integra's Avatar
wow i have a 1992 integra does the same thing after 60 it just doesnt go for crap with a b18a1 how many miles does ur motor have on it?
Old Nov 30, 2008 | 06:34 PM
dmpd_ef's Avatar
i would go w a b16 trans and a vtec head
Old Nov 30, 2008 | 06:51 PM
gonmaro's Avatar
Skunk 2 inteake manifold, larger throttle body, good CAI, Good exhaust system, Head work and a good tune.
Old Nov 30, 2008 | 07:04 PM
SlammedDC2's Avatar
Semper Fidelis
A bigger TB doesn't mean more power, You'd be better off having your TB bored to your IM. Get in touch with user Maxbore (i think that's how he spells it). I know in the past he was charging $80 which is cheaper than a new TB.
OP: If your just looking for a little more power why not ls/vtec it and put a gsr,b16 or itr tranny on. it will be a world of difference compared to what you have now.
Old Nov 30, 2008 | 07:29 PM
Schister66's Avatar
Man U FTW
turbo it and call it a day. You can build a rather simple setup for under $2500 start to finish and would be able to safely make 300whp on the stock block.
Old Nov 30, 2008 | 09:00 PM
whiteboy-dc4's Avatar
tb and im does add top end on the power band but ls trannys are slow at higher speeds becuase of the longer gears swap your tranny with a b16 if your not worried about going fast cuz the swap will make you quicker but top speed slower cuz of shorter gears
slwh22accord
Nov 8, 2006 12:40 PM
lude98SH
Nov 2, 2005 08:32 PM
92hatchattack
May 12, 2005 01:05 PM
caranjo
Feb 11, 2005 12:17 PM
