hand brake light
Old Nov 30, 2008 | 06:19 PM
ROM_lude's Avatar
Default hand brake light
it dnt turn off when i take the brake
off it stays on for a cool min
then it turns off
help? dnt know if its sumthin bad
hope nt well thanx for the help
Old Nov 30, 2008 | 08:09 PM
Kronn 98SH's Avatar
check brake fluid level
Old Nov 30, 2008 | 08:18 PM
prelude_93vtec's Avatar
Yep fluid level sounds like the problem. If not that, check the e-brake sensor..
Old Nov 30, 2008 | 09:01 PM
shutta's Avatar
i'm going with a sticky sensor. it's the same reason half of teh time the "headlights on" ring won't go off in my car when i park and leave the car. might need to be replaced or just cleaned up a bit. if some kind of contaminant got on it it could be sticking
Old Nov 30, 2008 | 10:03 PM
dre2day's Avatar
Check your fluid and move the floaty to make sure it moves freely while you check the fluid.
Old Dec 1, 2008 | 06:27 AM
Lovemy99Lude's Avatar
I had this same problem. I checked the brake fluid by opening the cap/lid under the hood. Took the cap off for a sec, then screwed it back on. I havent had a problem since with my sensor. Try that and see what happens.
Old Dec 1, 2008 | 01:48 PM
ROM_lude's Avatar
ok kool thanx for the help =]
Old Dec 1, 2008 | 04:49 PM
prelude1897's Avatar
I have this problem only when it's cold outside and the car has been sitting for a few hours. It always turns off after a short period of time
Old Dec 2, 2008 | 02:26 PM
Scheizty's Avatar
I thought my brakes were low from seeing my ebrake light do the same, but after adding fluid, the light doesn't come on, even when it's cold like it would before.
EJ1 guy in LBC
Jul 4, 2008 06:57 AM
pfourtythree
Apr 10, 2007 10:52 AM
sullycrx
Nov 16, 2005 09:48 PM
.water
Jun 11, 2005 12:06 PM
ITR184
Dec 3, 2003 05:40 AM
