So what goes bad when...
Old Nov 30, 2008 | 04:31 PM
runs with scissors's Avatar
Icon6 So what goes bad when...
Honda Prelude 1990-91
(The door frame has this: 11/'90, the registration: 1991.)
What happened is this kid (friend's son) who knows nothing about cars, was told by his neighbors that to fix his clutch pedal from losing pressure that he should bleed the lines. He promplty let all of the fliud out via the slave cylinder, then proceeded to pump the clutch pedal. He was really surprised to find the clutch pedal is now on the floor. It seems that no amount of bleeding the air out will get the pedal back up. It doesn't seem like there is any more air in the lines.
Um, so what else goes bad when one is stupid enough to pump all of the fluid out?
I felt sorry for the car and brought it home. I don't know that much about cars but I do know better than to let a hydraulic system run dry.
Any suggestions, please?
Old Nov 30, 2008 | 04:52 PM
Hawkze_2.3's Avatar
Bleed it and bleed it some more...then some more until you get a solid pedal.
What method are you using to bleed it?
Old Nov 30, 2008 | 05:41 PM
By pumping the pedal by hand, opening the bleeder valve on the slave cylinder to let out air/fluid. Never seem to seem to get any pressure. Have tried running a hose over the bleeder valve and into a bottle of clean brake fluid, still nothing. Thanks
Old Nov 30, 2008 | 06:04 PM
jlude90's Avatar
you need to hold the pedal down while you open the bleeder
Old Nov 30, 2008 | 08:01 PM
yep
Old Nov 30, 2008 | 10:01 PM
dre2day's Avatar
Yea keep pumping it will get it all out eventually
Old Nov 30, 2008 | 10:35 PM
I realize the keyword here is eventually, but how many bottles of brake fluid would you guys go through before calling it quits? I'm on the 4th one. What I need to find is a power/pressure bleeder but the guys at Autozone had no idea what I was talking about...
So, you guys don't think anything else got messed up? Thanks.
Old Dec 1, 2008 | 05:20 AM
Rob_O's Avatar
Try bleeding it with a mityvac
Old Dec 1, 2008 | 06:58 AM
G2IntegraGS's Avatar
It takes forever to bleed it that way. I would get one of the one man bleeders for a couple bucks at autozone. Makes the job way faster.
You just hookup a hose that connects to a bottle to the slace cyl where the fluid comes out. The you pump the clutch. Thats all there is to it.
Old Dec 1, 2008 | 09:46 AM
f22builder's Avatar
I did 1.5 bottles and another bottle the next day after driving around. No problems.
Old Dec 2, 2008 | 08:18 AM
Also, it seems like the fork has slipped off the bearing, it moves around fairly freely. This is gonna be a major thing...getting the fork back onto the bearing?
Old Dec 2, 2008 | 12:09 PM
jlude90's Avatar
requires transmission removal, and then you may as well do a clutch and replace that bearing
delsolsi193
11
Apr 7, 2009 09:46 AM
autoxthis
Aug 21, 2008 08:56 PM
autoxthis
Aug 21, 2008 08:23 PM
Dool_Ohver_Hed_Cam
Jul 3, 2007 06:01 PM
bradwcampbell
Mar 26, 2002 04:11 PM
