Few questions...
Old Aug 1, 2002 | 05:10 PM
done's Avatar
Default Few questions...
My daily driver: im looking for a eg, ef for a daily driver, planning on puting b16...
now heres my question:
Will itr cams run well with b16 intake manifold? and do usdm itr pistons fit in a b16????? is the bore right and hows that work??
Simpleily stated questions:
1. Will itr cams run well in a b16 with itr valvetrain?? and will the cams work with b16 intake manifold?
2. Will ITR pistons fit a b16?
thanx guys,
Jordo
Old Aug 1, 2002 | 05:12 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Few questions... (Jordo)
Being that the b18c5 is based on the b16 head, im pretty sure youll be fine with the cams and such. as for the pistons, no idea.
Old Aug 1, 2002 | 05:15 PM
ZygSpeed's Avatar
Default Re: Few questions... (Rguy)
Looks like the ITR pistons will fit in a B16A2, in that both are 81 mm bores, and people also put the CTR pistons in an ITR.
The difference in the displacement is due to the lesser stroke of the 1.6 L. Ed
[Modified by Zygspeed, 9:16 PM 8/1/2002]
Old Aug 1, 2002 | 05:18 PM
done's Avatar
Default Re: Few questions... (Zygspeed)
awesome thats what i wanted to hear, whats compression on a b16a2?? 10.2?
Old Aug 1, 2002 | 06:17 PM
fowler!'s Avatar
Okay, here is what you need to know.
Yes, you can put ITR pistons in the B16. But, I wouldn't waste the money on it.
Because of the shorter stroke, the ITR pistons will actually lower your compression.
CTR is the only Honda piston that will raise your compression (aside from the JDM version of the b16 piston).
Stock a USDM B16 comes with 10.2:1 compression
Stock a JDM 2nd Gen B16 comew with 10.4:1 and the 1st gen is the same as the USDM motor.
Old Aug 1, 2002 | 07:31 PM
done's Avatar
Default Re: Few questions... (fowler)
awesome, see i was gonna actually, when i mod my R, i was just gonna use stock parts to mod the daily driver..
Old Aug 1, 2002 | 07:56 PM
Tommy_Gunns's Avatar
Yes...don't put ITR pistons on the B16, you will lower the compression by quite a bit.
Think of it this way...
CTR pistons in B16B gives 11.5:1 compression (or there abouts)
CTR pistons in B18C gives 12.1:1 compression (or there abouts)
Someone needs to fix my compression numbers, I don't know them off the top of my head.
Old Aug 1, 2002 | 08:08 PM
MK Ultra's Avatar
Default Re: Few questions... (Tommy_Gunns)
Stock CTR (B16B) has about 10.8:1 CR, so CTR pistons in a B16A should be 10.8:1 as well.
A couple of my friends run ITR cams in their B17As with no problems. One of them has the stock IM (same as B16A) and the other has the ITR IM. The gains with the ITR IM are noticable, but only at the top of the rev range. As far as I know, both have stock valvetrains, but I believe they are also both using the stock 8000 rpm rev limit.
[Modified by MK Ultra, 11:11 PM 8/1/2002]
Old Aug 1, 2002 | 09:42 PM
done's Avatar
i was just gonna save money, by not buying pistoins or anytihng of that sort.. just use parts off the R
jbrokos307
Sep 29, 2011 05:44 PM
turbo_hatch93
May 21, 2006 11:02 PM
mrDFWmechanic
Aug 1, 2005 10:32 PM
libila
17
May 16, 2004 03:33 PM
VtecDA9
Jun 2, 2003 07:35 AM
