03 accord slow passenger window
On my 03 accord I recently noticed the passenger window is slow to roll up...I know this is a known problem, was there ever a recall for it...What can I do...the search option sucks now!
Thanks in advance!
Thanks in advance!
Like he said, clean and lube the run channel (as far down as possible). If that doesn't help, make sure the window is going up straight (not binding going up). If it is, the window may need to be adjusted/tightened in the regulator. If the window channel and regulator check out, your motor is weak. My guess is lubing the run channels will solve the problem. Just don't assume the motor is the problem. Good luck
xkrakenx
Apr 24, 2008 06:12 PM
manwezy951
Apr 2, 2005 09:14 PM
Chief Brody
Jan 4, 2005 11:21 AM
