Covert OBD II Injector on OBD I harness
Old Nov 30, 2008 | 03:16 PM
ISawUL00k's Avatar
Default Covert OBD II Injector on OBD I harness
i took my 97 ls motor and put it in my 92 hatch vx i converted my obd I harness to the obd II injectors and plugs. i dont think it works the car is missing slightly. anyone know if this is the problem? motor ran fine before swap.
complete obd II LS into 92 VX im using a OBD I LS harness
wants to die or dies. plugs are lookn lean.
it runs kinda, idles 750ish, runs ruff.
Old Nov 30, 2008 | 04:53 PM
iwanttokillgod's Avatar
if you wired it in correctly there wont be a problem
Old Nov 30, 2008 | 05:25 PM
mtber's Avatar
Are you throwing any codes ? (Check engine light)?
Start unplugging your injector plugs one by one to listen for a change in the motor or simply use a noid light to ensure all your injectors are pulsing.
94 OBD
Mar 14, 2018 10:07 PM
LSej1
Feb 26, 2012 02:48 AM
orientalgunz_00
Mar 15, 2006 10:55 PM
guyuenvy
May 16, 2002 12:27 AM
C1V1C
Apr 17, 2002 05:38 PM
