oill feed line and water lines t3 on em1
Old Nov 30, 2008 | 12:15 PM
EK_kidd's Avatar
Default oill feed line and water lines t3 on em1
i have a t3 turbo and its water cool too.
ehh where do i tap for the the feed line and water lines..
the links are broken on the FAQ and i ive seen is eg's
is it the same for em1??
Old Nov 30, 2008 | 12:16 PM
Ls_dx's Avatar
yes.
Old Dec 1, 2008 | 11:06 PM
project dc2's Avatar
water lines are pretty much anywhere on the motor where you can get them. preferrably one before the thermostat ( i.e radiator ) and one after ( i.e engine block) so coolant will always freely flow through.
oil feed is off the oil pressure switch out back. you and either run a tee off of it. or you can get a sandwich adapter such as one available from blox racing and bolt it on
h23vtec_dc2
Feb 28, 2010 04:47 PM
worx
Feb 1, 2010 01:33 PM
Emakulate
Aug 12, 2007 11:35 PM
adhana2
Apr 25, 2003 04:51 PM
asianspeed
Jan 28, 2003 04:30 PM
