driver side window off track
I just rolled my power window down on the front driver's side and it came off the track. Can anyone tell me how to remove the side panel to get at it and once I'm there is it easy to put back on track?
Thank You for any help you can provide.
You don't have to remove the tweeter, but it might make removing the door panel easier for you. These photos feature the driver's side door panel removal of a 2002 Civic EX Coupe.
Edit: When putting the panel back on: Start by putting the top right corner into the window channel, slide it all the way forward and then guide the lock through the hole in the panel. It helps make re-installation a little easier.
icefirezero
Jun 13, 2004 04:03 AM
