ClusterF@$K! rear disc brakes
Old Nov 30, 2008 | 09:46 AM
HonDA INTEGRATY's Avatar
Icon2 ClusterF@$K! rear disc brakes
new to honda tech
bought four new rotors and pads decided to start with the rears
screws on left rear rotor are destroyed (stripped) and have no idea what the proper procedure for changing the rear pads is.
Can't get the piston to go in far enough with 'c' clamp. Do I have to bleed brake fluid? Should I give up and take it to a shop? I really don't want to...it's sunday and I can't call and bother any Honda shops! Help!
Last edited by HonDA INTEGRATY; Nov 30, 2008 at 09:48 AM. Reason: forgot some shit
Old Nov 30, 2008 | 10:03 AM
sitinduk's Avatar
Best thing to do is go to hondahookup.com and get the helms manual.
If after reading through the pad/rotor replacement procedure you don't feel comfortable doing it, take it to a shop.
Now for the rear caliper piston, it has to be screwed into the caliper, not pushed in like the fronts. They sell a special tool for that at autozone, autobarn, etc. or you can use a pair of pliers (spread them into the groove and turn).
For the rotors, the caliper and caliper brackets have to be removed. If the rotor screws are stripped, you can try using an impact driver.
Old Nov 30, 2008 | 10:18 AM
danthemang3's Avatar
if the screws are messed up just drill the heads off. and like said above you have to screw the rear pistons in. just be aware on high mileage integra's the rear caliper pistons are know to seize. and no you don't have to bleed the brakes.
Old Nov 30, 2008 | 10:31 AM
super jdm yo's Avatar
for the rears, you don't push back the piston with a c clamp, it's something you twist back in.
Old Nov 30, 2008 | 07:52 PM
thank you guys so much I think I can do it...yeah I figured out you screw the rears in...I was reading the manual at autozone then the bitch was like...."hey this is for sale this ain't a library!"
I'm gona get to work first thing in the morning I'll figure out how to get those screws out or maybe just have a shop do that one it will be much cheaper
Old Nov 30, 2008 | 08:05 PM
AnDThEnWuT's Avatar
if the heads of the screws aren't too jacked up, you can use one of those impact drivers, the one you hit with a heavy mallet.
Old Nov 30, 2008 | 08:46 PM
Jimmy's Avatar
Global Moderator
yes..very effective.. you can pick these up at advanced super cheap!
mynameisChris
Aug 15, 2009 06:57 AM
kevinm1981
Aug 3, 2009 02:24 PM
blulude92
May 15, 2006 01:00 PM
JDMlyfestyle
13
Mar 22, 2004 11:04 PM
miataguy
Jun 15, 2003 05:44 PM
