90 CRX-B18A1 Swap... Half Shaft Problem
Old Nov 30, 2008 | 07:58 AM
SoDakCRX's Avatar
Default 90 CRX-B18A1 Swap... Half Shaft Problem
First a little background info:
I got a 90 CRX given to me: bare shell, stripped, poor body work, wiring hacked, and just generally a mess.
I purchased a 91 Integra LS wrecked in the rear with a b18a1. only problem was that it was an auto. wanting to convert to manual, i purchased a trans on ebay, long story short had a hole in the case. had a shop weld it up and had a transmission guy go through the tranny, everything looked good.
I am attempting to use the fronts suspension/axles/brakes etc. off of the integra. I read that you have to use a halfshaft that matches the transmission. not thinking the ebay listing for my trans could be incorrect, I purchased a b18 M/T half shaft. i say this because i was told when trying to use a b16 halfshaft with a b18 transmission there are some lining up issues.
While putting in the transmission, we had a difficult time getting the left side motor mount to line up. but finally after some adjusting, got everything to bolt up.
I just finished cleaning up and painting all the Teg suspension, and got it all installed.
went to install the half shaft, and it slides in without a problem, but where the plate on the end goes to bolt up, nothing lines up. in fact i cant even get the bracket to sit flush against the engine.
since then i have purchased 2 more half shafts to make sure it wasnt a b16/b18 issue, (one b16 and one b18) and neither of them work either
any help or ideas?
Old Nov 30, 2008 | 10:06 AM
Redline130's Avatar
Is the transmission bolted up straight and all the way to the block? All cable B-series half-shafts should bolt up no problem. In fact, cable or hydro half-shafts should bolt up no problem. Are you sure the half-shaft is all the way in the transmission? If everything is lined up and square, the half-shaft should work.
SoDakCRX's Avatar
sunofabitch
its a b17 transmission..... now i need a b17 half shaft from a 92 gsr
Old Nov 30, 2008 | 10:23 AM
dschenke's Avatar
let me help u on this
u bought a automatic halfshaft
i bought one from a guy tellinme it manuel but it isnt when u do get a manuel one keep ur auto one and put them next to eachother u will see the diff
but yea u got a automatic one
Old Nov 30, 2008 | 03:20 PM
ryanevansoh's Avatar
u should be happy u have a b17 tranny haha. lsd ftw!!!
Old Nov 30, 2008 | 06:38 PM
dschenke's Avatar
yea b17's r bomb great gear ratio n lsd
n cable?
sick!
Old Nov 30, 2008 | 06:44 PM
Crx Jimmy's Avatar
if the mid shaft is cockeyed like that its from an automatic
tigueremalo
Sep 3, 2007 01:42 PM
sacjdmz
Mar 19, 2006 08:26 AM
Fate
10
Dec 29, 2005 01:57 AM
90AcuraIntegra04
Mar 28, 2005 06:37 PM
90-CRXSi
Sep 14, 2002 08:19 PM
