transmission ground loose
Old Nov 29, 2008 | 06:40 PM
Neekstar's Avatar
Default transmission ground loose
hey everyone i have a 94 eg hatch with a 96 b18b1 swap and running a OBD1 ECU
When i put my swap in i noticed that the tranny ground was loose on the transmission side and when i tried to tighten it i saw that it was stripped and then i couldnt remove it. it is not super loose but it will move if you try to turn it pretty easily.
well my car sputters after it has warmed up and i try to accelerate WOT under 3k but once it is over 3k every thing is fine could the transmission ground be causing this?? i have NO CEL codes. and i checked the tps map and o2 sensors all are working. cleaned the Intake manifold and the problem persists.
any one think that the ground is the problem that is causing this? im starting to think it is and any ideas on how to remove the ground???
Old Nov 29, 2008 | 07:20 PM
teamworxek9's Avatar
if the ground isnt tight then yes it could be the problem. grind off the head of the 10m bolt drill and tap a new hole.
Old Nov 29, 2008 | 08:07 PM
Neekstar's Avatar
right now i just added a second ground to the tranny in the closest by bolt going for a test to see how it runs
Nicholas Bailey
May 13, 2016 05:04 PM
jake[eh2]
Feb 7, 2012 06:58 PM
chinkyx90
Suspension & Brakes
Jun 15, 2010 05:38 PM
thanh4o8
Suspension & Brakes
Jul 12, 2009 12:42 PM
JLefevers
Apr 21, 2009 07:10 AM
