LSVTEC TURBO BUILD..........Start!!!!!
ssuppp guys what it do what it is...............
ok i got a set of official TODA spec b (i think) or B-spec cams........the vtec lobe is like ultra retarded........
can i put those into my lsvtec turbo setup........????
if sooooooooooo what kind of work should be done.......??? general (valve job, port and polish) the whole nine???????
no need for your valve job or PNP
youll definitely need some valvesprings to run those cams. contrary to belief. some of the highest HP guys out there are running all motor cams on their boosted setups.
the turbo cams out there have shown to lose power than gain. What worked for V8's and other motors with lift and duration obviously did not pan out well for VTEC motors because they're a different beast all together.
all_motoref9
Apr 16, 2004 09:55 AM
viCeVerSa
Jan 18, 2003 10:00 PM
