JDM DC5 Problem
Old Nov 29, 2008 | 04:01 PM
S88HON's Avatar
Default JDM DC5 Problem
Hi guys
I have a JDM DC5 at the moment and the problem I have is that under WOT, 6-6.5K the motor seems to have a flat spot. I can see the rev counter needle during this RPM range go a little eratic! After this spot clears, from just under 7K the car pulls like a train.
What I have done to try to cure this problem so far.
CKP Sensor changed
Cam angle sensors changed (x2)
Primary O2 changed
Coil packs changed
Spark Plugs changed
Vtec Solenoid cleaned and changed for a known good one but still the same
VTEC oil strainer x 2 cleaned
Oil is fine
IAT changed
Mods are very stock, Mugen air box and an aftermarket exhaust.
Thanks in advance for anyone that can shed some light!
Old Nov 30, 2008 | 12:10 AM
eMpAtHy's Avatar
have you put it on a dyno to make sure there is actually a power dip that is bigger than the standard curve? there is a small dip in power right after it hits vtec.
Old Nov 30, 2008 | 02:58 AM
hawaiiancb74's Avatar
check your grounds, check your grounds, check your grounds
Old Nov 30, 2008 | 03:26 AM
S88HON's Avatar
Forgot to add, I also have an earthing kit!
Old Nov 30, 2008 | 03:27 AM
S88HON's Avatar
I never did have this problem with it before! its happened for a few weeks now.
lowtegsr
Feb 11, 2008 04:32 PM
rzz
Jun 20, 2007 10:24 AM
Rishiras
Oct 7, 2006 04:36 AM
Superman137
Jun 12, 2005 04:50 AM
prettyQuik
Mar 18, 2005 08:37 PM
