Leaking oil through head gasket? HELP
Old Nov 29, 2008 | 02:29 PM
duffman1278's Avatar
Default Leaking oil through head gasket? HELP
For some reason I seem to be leaking oil onto my block on the number 4 cylinder ONLY.
-The engine was rebuilt, I havn't even gotten a chance to drive it around(one of my ball joints is broken.)
-Seems to be coming from the head gasket(put a new one in from honda).
-Head has new guides and gaskets.
My questions would be then, why do you guys think it is leaking from there? I noticed that, that header starts getting covered in fluid as I leave the engine on. I know that I torqued the head down to spec and in the order that the Honda FSM says to.
Old Nov 29, 2008 | 06:55 PM
kronikSLOW's Avatar
did you check the block and head for flatness using a ruler? i whould say warped head.
Old Nov 29, 2008 | 06:58 PM
dawhiteghost237's Avatar
or maybe even a crack in the head
Old Nov 29, 2008 | 07:05 PM
B18C1CYA's Avatar
Ok first off that is the #1 not #4 , I would take a look and your can seals and gally plugs on that end of the head , if you look realy close at the pic it is shinney behind the plastic timming cover with means the leak is up higherand is running down.
Old Nov 30, 2008 | 06:13 AM
the_augie's Avatar
there looks to be a nick where the head meets the block right there, close to the manifold. did you pry the head off there initially? that could be your prob. take the head back off, make sure its flat. if it is, then check back here. if it isnt, take it to a machine shop to be milled 0.005 over. that will get it back to flat without affecting performance/engine health.
Old Nov 30, 2008 | 07:54 PM
Ellis's Avatar
Default 94 accord 2.2 vtec
i have the same problem i changed the head gasket bc it was blown and i sent the head off to get checked and put everything back together now oil is leaking out the back of #1 cylinder any ideas
Old Jan 1, 2009 | 08:42 PM
Default Re: Leaking oil through head gasket? HELP
^^^ I fixed my problem. It ended up being the exhaust camshaft seal. I replaced it and it stopped leaking.
Old Jan 2, 2009 | 04:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
awesome, glad it was a relatively easy fix. I always replace camshaft seals whenever I change my timing belt.
thewrai6th
Oct 12, 2009 03:45 PM
ITR_1211
Jan 5, 2004 09:04 PM
R6Elmo
Nov 13, 2003 04:47 PM
fiftee_su
Oct 8, 2003 09:23 PM
