6th honda civic gsr swap
Old Nov 29, 2008 | 02:19 PM
4drteg54321's Avatar
Default 6th honda civic gsr swap
Okay, I swapped a Obd1 Gsr in a Honda Civic 1998 EX. i did all the wiring. Am using a obd1 alternator and obd1 distu from my gsr. I also did the Crank sensor bypass. Here the problem the car will barley try to start i have to crank it a few times, when it does start it will idle a bit and then it will die when i push on the gas pedal. what cause this? Also am still running the obd2 ECU that came with the civic. Even using that Ecu wouldnt it still Idle?
Old Nov 29, 2008 | 02:38 PM
Hanmin's Avatar
check your tps.
Old Nov 29, 2008 | 03:04 PM
Can anything esle cause this?
Old Nov 29, 2008 | 05:06 PM
808Army's Avatar
fuel? any codes
Old Dec 24, 2008 | 07:01 AM
Default Re: 6th honda civic gsr swap
yeah i have fuel. So i put my obd1 ecu on but it only ran good once. Is there anything else am not seeing?
Old Dec 24, 2008 | 08:01 AM
Anon51's Avatar
Check Fuel Pump, and plug the obd1 ecu in and get codes. or do what i did and convert the obd1 b18c to obd2. and use the p72 ecu. also what ecu are you using? stick or auto?
niceprelude
Mar 2, 2009 03:08 PM
3rdgencrx
12
Feb 14, 2007 05:26 PM
DOMKID
Feb 22, 2006 03:52 PM
