question for the turbo zc guys.....
the pr3 ecu is an obd1 correct? you're using this on your obd0 zc.......is it functioning properly.....no-vtec either are you getting any codes or did hondata take care of this for you
PR3 that I have is an OBD0. It has the same plugs as the 86-89 Integra and 86-91 JDM ZC. You need to do a little bit of work to get it to work with the Hondata, but it can be done (disable the VTEC solenoid).
Sonny
Sonny
92-95 Civic comes with a P06 (non-VTEC) or a P28 (VTEC).
The OBD0 PR3 comes from a JDM B16A powered car like the 88-91 JDM CRX Si/Integra Xsi.
Sonny
Sonny
i thought hondata could only do obd 1-2 ecu's
Sonny
iheartmyh0nda
Apr 23, 2007 09:59 AM
-=TWITCH=-
Feb 17, 2002 08:46 AM
