====H22 H2B PART OUT Everything you need====
Old Nov 29, 2008 | 10:35 AM
SIXTY's Avatar
Default ====H22 H2B PART OUT Everything you need====
Jdm H22a Head - SOLD
Boomslang obd0-obd1 jumper harness - SOLD
OBD1 VTEC ecu - SOLD
Innovative Mounts b-series/cable trans into ef - SOLD
DA Rear T-bracket - SOLD
H22a block - SOLD
-RS Machines 90mm bore
-14:1 Arias Pistons
-Oem 90.7 Honda crank knife-edged by castillos.
QSD H2B EF Kit - SOLD
H22 distributor - SOLD
H22 IACV - SOLD
H22 Skunk2 valvetrain - SOLD
H22 skunk2 cam gears - SOLD
ExplicitSpeed h2b lower d-series alternator relocation bracket - SOLD
arp h22 head studs - SOLD
B-series fidanza 8lb flywheel - SOLD
H22 Skunk2 pro series intake manifold - SOLD
BLOX H22 camshafts type b - SOLD
h22 hot-shot header - SOLD
68mm professional products tb - SOLD
RC 550cc peak and hold injectors - SOLD
manual tensioner complete conversion - SOLD
single row crank pulley - SOLD
Old Nov 29, 2008 | 12:57 PM
SIXTY's Avatar
ttt
Old Nov 29, 2008 | 04:38 PM
SIXTY's Avatar
ttt
Old Nov 29, 2008 | 04:44 PM
SP GARAGE's Avatar
damn i want some of this stuff
Old Nov 29, 2008 | 05:10 PM
joeyjoeysee's Avatar
what chassis is the h2b kit for?
Old Nov 29, 2008 | 05:48 PM
"NastIE Garage"'s Avatar
ttt
Old Nov 29, 2008 | 09:16 PM
ptftw's Avatar
pm'd
Old Nov 29, 2008 | 10:26 PM
SIXTY's Avatar
Ef model, the kit will work in any model, just need a driverside bracket specific to your chassis.
Old Nov 30, 2008 | 01:24 AM
Rav's Avatar
Rav
bump for a nice build im jelous hate to see it being parted
Old Nov 30, 2008 | 06:32 AM
SIXTY's Avatar
Me too.
Old Nov 30, 2008 | 08:14 AM
SIXTY's Avatar
ttt
Old Nov 30, 2008 | 11:53 AM
SIXTY's Avatar
ttt
Old Nov 30, 2008 | 06:51 PM
SIXTY's Avatar
bump
Old Dec 1, 2008 | 06:33 AM
SIXTY's Avatar
pms replied
Old Dec 1, 2008 | 10:28 AM
SIXTY's Avatar
ttt
Old Dec 1, 2008 | 11:31 AM
h22crxpwr's Avatar
Originally Posted by SIXTY
ttt
i'll give you $500 for all of it....
cash..
lol..
Lots of good parts here!! the block has custom pistons! H2B kit... mounts..
Almost new Blox B cams!
Up to the top for some buyers!!
Old Dec 1, 2008 | 02:33 PM
sp3nce's Avatar
how much power are you making with this set up?
Old Dec 1, 2008 | 06:12 PM
ilikehonda's Avatar
what are the specs on the header?
Old Dec 2, 2008 | 07:15 AM
SIXTY's Avatar
I made 240 whp.
4-1 with a 3" collector that reduces to 2.5"
Old Dec 2, 2008 | 11:19 AM
slojdmcrx's Avatar
pm'd u...thanks
Old Dec 4, 2008 | 02:06 AM
SIXTY's Avatar
pms replied
Old Dec 4, 2008 | 02:26 AM
commandff's Avatar
Are you flexible at all on that block price?
Also; what rods are in it; and how many miles/runs since the last bore was done?
V/r,
Mike
Old Dec 4, 2008 | 07:06 AM
SIXTY's Avatar
It has about 30-40 1/4 mile passes on it. No street driving. It made 290 compression even across all cylinders before i pulled it.
Old Dec 4, 2008 | 10:31 AM
Moe*PG+K's Avatar
is header still forsale? if so would it fit an h22 eg hatch?
Old Dec 4, 2008 | 11:28 AM
sauceja's Avatar
bump
