Precision 6262 Billet wheel? Compared to?
Im looking into the new billet wheel turbos from precision. Specifically the Precision 6262. There is a local evo running one making 740whp @ 42psi on E85.
Just wanted to see if any of the honda guys are using this thing.
The turbo is great. We had a 83mm GSR on the dyno today with one. Had a basic setup with GSR cams and a 6262 .63a/r Turbo. Made 536whp at almost 21 psi and 110 octane. I will post the dyno chart Monday. Turbo definately has 7xxwhp in it.
would like to see the chart im sure you've seen my thread about my gsr build.
I talked to a few people that said the loss of spool of the 6265 vs the 6262 was not worth it. I have not used one myself though.
Here is the dyno chart for the car I was talking about.
And some pictures..
http://www.speedclinic.net/showroom/...?g2_itemId=638
And some pictures..
And some pictures..
And some pictures..
Exactly what i was looking for!
When I was at PRI I sat in on a seminar hosted by Garrett. At the end they opened the floor for questions and I asked their insight on Billet Wheels and Extended Tip Wheels. The Garrett Rep said that the billet wheel is solely a less cost effective way of mass producing compressor wheels. IF this is true, why is it costing us more to purchase these turbo's when it's costing them less to manufacture them? You'd think the cost savings would also trickle down of us guys to?
I am in no way implying that what the rep said was 100% true. I am just trying to shed some light on it and see what others have to say about it.
I am going to have to say that rep. was leaving out alot of important facts.
Billet vs cast wheels. Billet is lighter, stronger, allows for more aggressive aero design, can tolerate higher tip speeds, smaller hub which means a billet wheel has more area than a equal size cast unit, etc...
I figured it was and yes it probably does cost less for just the actual manufacturing a billet wheel. Also I would bet they can rapid prototype, test, and even make changes in designs MUCH faster and easier than traditionally what was done with cast counterparts.
The initial cost increase I think is for r&d, marketing, tooling and other overhead... etc. I think pricing will come down a bit as the market gets more competitive, initial investment cost is payed back, and whatnot.
**** wanna talk expensive, look at garrett's true billet units or other billets the diesel pullers been running for a while now... those things are some $$$.
I'm a lot more interested in what he had to say about extended tip wheels, what did he say about those?
I THINK than some holsets come with billet wheels, like i said i think im not positive but i remember someone in dsmforums saying something about what vehicle did the holset with the billet wheel come off of? And while im on this subject does anyone know the answer to that question what vehicle did the holset with the billet wheel come off of?
Also another question, how much on average do these cost? can you get a the precision 6262 in DBB form because i can definately tell from the dyno that the 6262 wa not DBB? If so how much do they cost and would you guys say the spool of the 6262 compared to the 35r? If not does precision offer something comparable to a 35r? I saw on evans that precision makes a 35e, jeff said it was a 35r with an e comp. cover but im not sure if it was actually DBB or not.
Also can you get a 35r with a billet wheel? and if so how much does it add to the price?
I wish precision would update there webpage on what turbos they offer its almost 2yrs old. Is there anywhere to see what they offer other than calling them? Sorry if i got slightly off topic but i would like to know more about billet wheels in general,
anyone else notice this? 62whp is a lot if the .82 didn't change the spool time then that means those cams are REALLY good
The Garrett rep just said that they haven't done any testing on those turbos to give a valid opinion and Garrett has no intentions to incorporate some kinda extended tip technology to their turbos.
Dont the Billett Wheels allow a more aggressive pitch to the wheel due to their strength and I am pretty sure they flex less also at higher pressures, which allows an overall higher boost pressure over what a standard wheel would be capable of.
