2000 gsr rear seats in 95 ls drama!!!
Old Nov 29, 2008 | 08:44 AM
JDMJAYDC2's Avatar
Default 2000 gsr rear seats in 95 ls drama!!!
ive wanted black leather seats forever in my ls well finally lucked up and got a set took out my dusty cloth ones and to my surprise the mounting holes for the bottom pan didnt match up no big deal i thought to myself then i tried mounting the back rest section and this didnt mount up either the small metal poles that you must slide to one side to remove were mismatched on my cloth seats were there was a pole on the leather seats there is no pole so clearly it wont slide into my car like it should so as of now my rear seats are only mounted with the small tabs that click in when you pull the up the little pulley thing i hope im making sense pics will be up by monday to help with confusion i hope someone has done this and can help me with my drama
and to avoid the question do i have the seats installed on the correct side yes i do the small plunger or thing you pull up to let the seat down is near the window on each side of my car they just wont mount up to the small poles near the bottom of the seat
Old Nov 29, 2008 | 09:22 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
94-01 Integra seats use the same mounting pattern for both front and rear, that is a coupe will match a coupe & sedan will match a sedan.
If you picked up 00 seats, they should fit perfectly.
Not sure what problems you're facing but pics would really help.
Old Nov 29, 2008 | 11:15 AM
itr#1334's Avatar
Yeah what he said. Iv swapped many rear seats out. Matched up perfectly.
Old Nov 29, 2008 | 04:10 PM
fcfromhell420's Avatar
the seat backs should fit no problem, i have 2000 seats in my 95
the seat bottems do not fit directly in, you will need to swap you leather cover over to your stock frame, if you can i have never tried it
the 2000 has a extra frame that bolts to the chassis along the front of the rear seat bottems, you could get them but you will have to find a way to bolt them in, this i what i did, also you will have to moddify the big side moldings for all this to fit
big.turbo.daddy
Jun 1, 2014 08:35 AM
exz0n-.-
Nov 12, 2008 08:14 PM
Budget EJ
Jun 1, 2006 08:41 PM
Civicr2gs5
15
Nov 27, 2003 05:31 PM
EKFerioHawaii
May 23, 2003 01:23 PM
