Transmission Going Bad or is it my clutch?
My transmission makes noises when i put in gear. I push the gas and let the clutch out slowly and the transmission has a rattling sounds but it aint that loud and once it made a loud grinding noise. When ifloor it it wont go into gear it will just grind.
Ur actually better off dropping and OPENING up your transmission and just finding out precisely what is wrong. Many people can e-diagnose real well, but nothing beats actually getting your hands in there and finding out. Maybe its worth the fix, or maybe not but then you won't be haunted with wandering 'what-ifs'
Does it grind in EVERY gear while doing the shift, or does it only do it in first?
Could be internal to the transmission (bearing and synchro combination).
Could be clutch related (broken springs, etc).
Could be motor mounts and shift linkage.
But YOUR eyes need to get in there, look, and SEE what it is.
yeah it grinds nearly every gear almost every time. i cant shift smoothly most of the time. i got to force it in and its starting to slip out in third gear very easy. but yeah i can feel like alot of resistance when i shift.
its probably a broke spring in the clutch disc i jus had to replace the clutch in my girls integra cause it was doing the same thing..
well i can tell u that i bet ur tranny is gone now b/c u drove it with a ****ed up cluthc and ****ed all ur syncros up. if its that bad where every gear isa grinding then junk it but i bet it all started b/c u had a bad clutch or broke ur clutch. wat kind of clutch and how old? wat tranny and how old?
i did syncros in mine a while back for 3rd and 4th gear b/c they grinded but they wernt bad, happened b/c smoked clutch and kept bangin gears. recently had some tranny noises and we dropped the tranny and had snapped 4 teeth off of my final drive gear and ruined my bearings with metal shaving. so replaced the bearings and final drive and put another new clutch and its good as new.
