So... Turbo or SC?
So i am about to do 1 of the 2... I have a 2d red 08 Si. I have been looking at the Comptech bolt on.. or the Greddy full bolt on kit? they both are about the same price... What do u guys think?
Road House
To my understanding, turbo applications are still rather difficult to tune at this point.
And allegedly if you have the comptech installed at an Acura dealership, you're covered under warranty.
It should not matter whether it is a Honda or Acura dealership.
In years past Comptech worked closely with Honda to develop their S/C kits and as long as you left it as it came and didn't up the boost or anything like that, your warranty was still good. I have not heard if that still stands with the new division formed under CT Engineering.
So Bubz i have no real idea how to install the S/C. Is it hard? i have a coupe SI not 4d. What else do i need with the Comptech kit? I mean headers, intake, and cat back. but i mean outta the box its 6 pounds of boost right?
TURBO!....You can use the AEM Fuel ignition controller to do your tuning or the Greddy emanage ultimate. With proper tuning you can achieve higher power with a turbo. I'm not sure but I think with the s/c you can get much more than 250 to 280 wheel horse power. As long as you have a good tuner 300 to the wheels is no problem with a turbo. I'm at 5.5 psi on my ajp turbo with 300whp. I can run more but don't need to since were rolling into Winter and can't get traction in second gear any way. It was a little pricey but don't regret it at all
To OP, I think you should think about your power goals and what exactly you want to build the car for whether it be drag racing, autox or just daily spirited driving. If you want to make the most power possible and have a setup flexible enough to make more down the road after you build the motor, I would say turbokit. If you're going to take it to the drag strip, deffinatly turbo kit.
-Zol
I just want a little more HP and a bit of fun. thats why i am leaning towards a S/C now cause i mean i still need intake headers and catback.. turbo kit all i need is catback. the car is a everyday driver and i dont really take it to the track i want something reliable and quick.
Neither, without a good ems this will significantly shorten the life of you motor. You should wait until hondata releases the dual ecu for our cars. This engines can make serious power with a good ems, give it some time.
